Results 1 to 10 of 14
Thread: identifying a 4a block
    Jun 2011
    bazz
    nsw
    sydney
    Default identifying a 4a block
    Im trying to identify a 4a engine
    had for a few years and going to put iot in until i build a proper one
    its a 3rib engine with 8 bolt crank
    but when i was giving it a clean it has the 7rib cams (7rib or small port)
    then it has the engine number in a stright line n ot offset like the others ive seen
    it also has a different casting at the back of the intake side
    the sump seems 16V type
    any help identifying it would be appreciated
ID:	37710Click image for larger version.
ID:	37711Click image for larger version.
ID:	37712Click image for larger version.
    West
    Just pull the head off it and see what pistons it has? See whether someone slapped something together oddly or if its a regular 3 rib 16v bottom end. I thought bigport cams were better? Seems like an odd swap.
    Jun 2011
    bazz
    nsw
    sydney
    The cams have definitely been swapped. so i assume most likely the whole head. So it could be a 4ac, but then it would be a 6 bolt crank. it could be a 4afe. im not sure what those blocks look like and they can come 8 bolt.
  • #4
    Jun 2011
    bazz
    nsw
    sydney
ID:	37714Click image for larger version.
    All 3 ribs ive seen look like thise. Have that casting on the intake side and have the engine number offset.
    An d dont have that f8 casting
  • #5
    West
    Thats real weird. On closer inspection, there are some three rib 16vs with that rounded casting on the inlet side but I cant find a shot of the engine number to confirm its linear.
  • #6
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Looks like a standard 3-rib Bigport block to me?
    For pictures of both 3 and 7 rib see post #15 here:
    http://www.ae86drivingclub.com.au/fo...question/page2
  • #7
    Jun 2011
    bazz
    nsw
    sydney
    Yup seen that. It has the cast "bump" this engine doesn't. So it sure if it's a 4ac black or a 4afe or 4age
  • #8
    Veteran timbo's Avatar
    Tim?
    Wild West
    And to spice things up:
    In my AE82 I have a 3 rib block, engine number in a straight line with a 42mm crank, large gze/smallport rods with bigport pistons...
  • #9
    Jun 2011
    bazz
    nsw
    sydney
    What size are the wrist pins? That's an unusual setup. But the block sounds like it's the same one. Is it a factory engine?
  • #10
    Tim?
    Wild West
    Can't remember but I'd say 20mm as I've never heard of those size rods being otherwise. First time I realised was when I rebuilt it and the big end bearings from a bigport kit didn't fit. Sure is the most bizarre 4AGE I have ever seen and I would assume that it was the last of the old 3 rib blocks as they changed over to 7 rib bigports and had no 40mm cranks left.
    edit: no idea if its the original engine or not. It will be stripped at the start of next year and I will keep the motor as a Toyota oddity.
  • Page 1 of 2 1 2 LastLast
    1. Identifying LSD?
      By Sambo NZ in forum Technical - Questions
      Last Post: 18th September 2013, 01:58 PM
    2. WTB: 4age bare block 3 or 7 rib syd area or 4agze short block
      By aussierider in forum Cars or Parts Wanted
      Last Post: 4th May 2013, 06:00 PM
    3. help Identifying what motor I have
      By Dexter in forum Technical - Questions
      Last Post: 19th August 2012, 10:18 PM
    4. Identifying LSD
      By KurtHS in forum Technical - Questions
      Last Post: 30th May 2010, 10:26 AM
    5. Need some help identifying parts
      By Doylie in forum Technical - Questions
      Last Post: 29th June 2009, 12:19 AM
