Results 1 to 5 of 5
Thread: Advice on Spring rates for 1UZ AE70 Corolla
    Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Advice on Spring rates for 1UZ AE70 Corolla
    Hello Friends!
    i just completed my 1uz ae70 swap (after 3 years)...heheh... Car is insane!!
    i would like some advice on what spring rates are appropriate for my setup. engine is a stock 1996 1UZFE with a W57 and a hilux diff and 195/50 r15s. I intend to use the car mainly for street (racing)/ weekend driver.
    Thanks
    Max.
    Veteran Konakid's Avatar
    Henry
    Eastern
    I would start with something around the 5kg Fr and 3.5Kg rear and get a feel for it from there. 7 and 5 is normally good for drifting so the softer rates will be good for the street with bumps and also some squat for extra grip with the power level you now have.
    RT142 Estate.
    AJPS.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Thanks for your reply!
    Considering the added weight of the 1uz, i was of the view
    (guesswork) that perhaps i needed a slightly higher rate in the front...so i was leaning towards 7/5.... turns out it's more of a drift setup than street. Unfortunately, i had already acquired 5kg eibach springs for the rear.... was still saving up for the fronts...
    So now I'll put them back in the box and try your recommended setup for starters..
    How does a 6/4 setup compare?
    Cheers.
    Henry
    Eastern
    Dont overthink it. Run the 5kgs in the rear and see what you think. Get some 7kg for the front. with the heavier diff, gearbox and motor they will probably be ok, similar to a 6 and 4 setup. Will probably still be on the stiffer side for the street though. The 1uz is all alloy block too so it isnt as heavy as you would think. I had 6 and 4.5 in my corolla years ago and this was a good street setup, not too stiff but definitely on the limit for the street.. i then went to 8 and 6 and it was very stiff mainly good for drifting. it didnt like the bumps in the hills roads too much.
    Make sure you get some good hocks to dampn the springs too
    RT142 Estate.
    AJPS.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Turns out that 5kg in the rear is waaay too stiff for any reasonable/enjoyable driving on street roads. Car is bouncy allover the place and has limited grip.
    I'm thinking 3kg springs would calm things down pretty well.
    Max.
  1. Harder spring rates, ride height and compressed rates.
    By Breaka in forum Technical - Questions
    Last Post: 13th November 2009, 01:12 PM
  2. Spring Rates
    By riojin in forum Technical - Questions
    Last Post: 11th November 2007, 02:48 PM
  3. Spring Rates
    By Dan_AE86 in forum Technical - Questions
    Last Post: 12th October 2007, 04:24 PM
  4. Spring rates
    By thekid in forum Technical - Questions
    Last Post: 17th November 2005, 02:16 AM
