Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Freedom ECU users
  1. #11
    Jul 2018
    Eddie
    Jamaica
    So there’s a little screw on the computer, I adjusted it a little bit... my idling is ok but I’m not so sure about my fuel consumption the car is now responding when I disconnect the map sensor I’m happy because the car is driving better..... I’ll fill up my tank in the morning and tell u about it....
    Sent from my iPhone using Tapatalk
  2. #12
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Hi Edward
    That little screw adjustment selector, basically is a selection of 4 different Map , that you can select , by turning that selector with the screwdriver.
    The map that you were using most probably was adjusted for a specific engine set up.
    What you did , it went to a another program/map , with a basic program that came from a factory.
    Normally , you will select different setups for different engines or fuels.
    Hopefully that works for you
    Juan
  3. #13
    Jul 2018
    Eddie
    Jamaica
    But now it takes long long to start ??
  4. #14
    Jul 2018
    Eddie
    Jamaica
    What can this ecu really do? I’m loving it so far I wish I could get a tuner on it
  5. #15
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Almost anything, but it will depend what extras has from factory.
    You could change fuel, ignition, minimum, water coreection etc
    It was designed just to plug and play , and it will recognize all the factory sensors
    But, downturn is , not many people knows them
    Only in japanese
  6. #16
    Jul 2018
    Eddie
    Jamaica
    Oh... the car is fast and fuel efficient but boring I need launch control and explosion when shifting gears at a high rpm
  1. Freedom ecu users forum
    By tottacrolla in forum Technical - Questions
    Last Post: 24th January 2016, 04:33 PM
  2. freedom ecu
    By dehney in forum Technical - Questions
    Last Post: 9th July 2011, 11:45 PM
