Results 1 to 10 of 12
Thread: Need help with 4A-GE running issue, please
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Default Need help with 4A-GE running issue, please
    I've only owned my car a few months. (A 1981 Toyota Starlet with a 4A-Ge swap)
    I had to replace the transmission, all the brakes including the almost impossible to find brake booster, etc. It ALWAYS started and idled very high. But otherwise ran well. I figured it was an issue with the coolant controlled idle circuit....
    A few days ago, I replaced all of the belts and hoses. I found a LOT of rusty sludge in the idle control lines and the idle control itself. I cleaned it out. But upon replacing the coolant and bleeding the system, The car now surges at idle and will not rev up. The speed pulsates up and down and pops and sputters if you give it any throttle at all.
    I have just ordered an idle control block off plate to remedy my original issue of very high idle and now surging idle. My question is, would/could that circuit also make the car not want to rev? Quite simply, I didn't mess with anything else. It ran well.....I replaced the hoses, coolant and the alternator belt and now it doesn't want to run well. I didn't mess with the timing or touch anything electronic.
    Thank you!!
    May 2010
    Tyrone
    Caulfield
    Nevermind
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    My guess is that you have loosen up rust and it is now lodged in the wax-stat not allowing it to close. You have to remove the wax-stat and blow out the rust with compressed air. While you have the wax-stat off. I would also soak the wax-stat in carb cleaner for a couple hours and try to remove the vanish around the spool valve. Then blow it out or use spray carb cleaner to flush out the build up. This cleaning should reduce your idle speed. If you feel adventurous, go to the club4ag forum search wax-stat, for how to dis-assemble the wax-stat and adjust it with a home made tool. But be warned that the pins on the adjust tool need to be on the short side to actually work. Davew7
  • #4
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Would a leak or malfunction in this system also cause poor running in general?
    The engine now sputters and hunts up and down while trying to rev the engine.
    I've ordered an idle control delete plate. I live in Florida. Cold starts aren't a big issue here.
    Since i didn't touch ANYTHING else, I'm assuming that the whole thing is trapped air. Especially after removing the control valve and seeing the big, honking hole that lets the engine gulp air when that pellet assembly is stuck open.............
  • #5
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Thanks
  • #6
    West
    If you had the throttle body and or manifold off you might have a split gasket and created a vacuum leak that would cause this issue. Erratic things are usually caused by erratic situations, like a vacuum leak that gets worse as the demand for air gets greater.
  • #7
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I've got to say that I like your logic!
    However, at that time, all I'd done was replace the radiator hoses.
    It's apart now and I'm using new gaskets for the re install. However, it'll be a week before I get the gaskets and the block off plate.
    This is the car. BTW
  • #8
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I can't easily post pictures. Sorry.
  • #9
    West
    Car looks sweet dude.
  • #10
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Thanks
  • Page 1 of 2 1 2 LastLast
    1. 4age wont start, was running, possible wiring issue
      By skizzamods in forum Technical - Questions
      Last Post: 25th July 2014, 08:52 PM
    2. charging issue with my drift car running 15.5volts
      By slider4life in forum Technical - Questions
      Last Post: 30th August 2012, 10:25 PM
    3. 7age running cold - changed thermostat and now its running hot
      By boh086 in forum Technical - Questions
      Last Post: 18th January 2011, 08:33 PM
    4. 4K-C idle and running issue.
      By AE86 Spoontah in forum Technical - Questions
      Last Post: 14th June 2010, 09:05 PM
    5. 4AC issue
      By lawrencelalot in forum Technical - Questions
      Last Post: 20th May 2010, 03:26 PM
