Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Need help with 4A-GE running issue, please
  1. #11
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I should have that block off plate by this weekend. So soon I'll be able to answer the question about if that air leak can cause non revving problems also..................
  2. #12
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    So, I installed the idle block off plate. Started up the car and it STILL surged in idle. I retarded the TPS and the idle smoothed out, but the car kept surging and sputtering when I gave it the gas pedal.
    I found that if I disconnected the TPI altogether, the idle issue as well as the revving issue went away and the car runs sweet. Then I noticed that the return spring in the TPI doesn't work...At all.
    So I've ordered a new TPI and we'll see if it's all good then.
    In the meanwhile, I am reluctant to run the engine much without a position indicator.
  1. 4age wont start, was running, possible wiring issue
    By skizzamods in forum Technical - Questions
    Last Post: 25th July 2014, 08:52 PM
  2. charging issue with my drift car running 15.5volts
    By slider4life in forum Technical - Questions
    Last Post: 30th August 2012, 10:25 PM
  3. 7age running cold - changed thermostat and now its running hot
    By boh086 in forum Technical - Questions
    Last Post: 18th January 2011, 08:33 PM
  4. 4K-C idle and running issue.
    By AE86 Spoontah in forum Technical - Questions
    Last Post: 14th June 2010, 09:05 PM
  5. 4AC issue
    By lawrencelalot in forum Technical - Questions
    Last Post: 20th May 2010, 03:26 PM
