Results 1 to 1 of 1
Thread: The Golden Era of Turbocharging
    Senior Member Bridgestone's Avatar
    Sep 2014
    Rob
    Seven Hills
    Default The Golden Era of Turbocharging
    The turbocharger was once a little-known technology reserved for performance cars and high-end stuff, but now its mainstream and is expected on most new cars. The push for turbocharged engines is simply a result of tightening emissions targets that cant be achieved with fuel-hungry, normally aspirated engines.
    In a nutshell, a turbocharger is a turbine that spins when exhaust gases pass it, causing its other side to spin and compress incoming air. The compressed air contains more oxygen thus detonating better in the engine, providing more power.
    Once the compressed air enters the engine, the computer sends more fuel than normal to help it detonate, so more power is generated, but if the engine is not revving hard - or theres not much throttle input - the engine only uses as much fuel as it would when normally aspirated.
    The result is as much power as a bigger engine when you want it, but with the efficiency of a smaller engine when you dont.
    Traditionally, the secret to gaining more power was to have a bigger engine. And its true, to an extent. But the efficiency of modern turbochargers, combined with direct fuel injection, means that small engines can now punch above their weight when it comes to power. And even better, its able to maintain the fuel economy expected of the smaller engine size.
    More manufacturers are now adding turbocharged engines to their line-ups even larger vehicles such as SUVs which are increasingly featuring small, four-cylinder turbocharged engines as the main power plant.
    The introduction of powerful, reliable turbocharged engines that are smaller in size are having such an impact that traditional naming convention is going out the window. BMWs 330i, which was once a 3-series with a 3.0-litre six-cylinder engine, is now a 3-series with a 2.0-litre turbocharged four-cylinder, for example.
    Up the pointy end of the spectrum, were also seeing a departure of normal aspirated engines from supercars, replaced with smaller, lighter and more powerful turbocharged variants.
    Eventually, as emissions targets tighten even more, well see manufacturers combining smaller turbocharged engines with electric hybrid technology, all in a bid to lower pollution but provide similar levels of power provided by the traditional internal combustion engine
    Are you team turbo, or do you only have time for big, grunty engines? Post a comment below or over on Bridgestone Australias Facebook.
    LINKS:
    Bridgestone Australia - www.bridgestonetyres.com.au/
    Bridgestone Australia Facebook - www.facebook.com/Bridgestone
  1. golden years
    By MR86ER in forum AE86 Owners Forums
    Last Post: 3rd June 2012, 09:40 AM
  2. 4age after turbocharging. What do I do with the breating cam cover??
    By killapotatoe in forum Technical - Questions
    Last Post: 18th March 2011, 11:17 PM
