Results 1 to 3 of 3
Thread: How much fuel pressure?
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Default How much fuel pressure?
    My KP61 fuel tank is in horrible, rusty shape. I'm replacing it with an inside the car, outside venting, aftermarket, aluminum tank and want to also replace the lines from the tank to the 4-age stock fuel rail and the return back to the tank with 5/16" braided line.(it's currently a mix of 5/16" and 1/4"Fuel injection hose)
    I have a stock, but not to the car 4-age.
    How much fuel pressure does say a stock AE86 have/need?
    I don't want to order an aftermarket pump with too much or too little and if I do, I'll need to know how much to dial into an aftermarket fuel regulator.
    This is NOT a race car. But it is starting to look like one. A fact that is fine with me.
    Thank you.
    Ed
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    40psi is about right for a stock 4A-GE powered Corolla. A standard replacement pump is fine, no need for a massive Walbro/Bosch etc.
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Thank you.
    Other than the Starlet having the 1/4" steel lines for its tiny carburetor. Replacing them with 5/16" is all I will do then. The fuel injection pump I already have seems adequate.
  • Similar Threads
    1. Replies: 16
      Last Post: 8th March 2016, 10:48 AM
    2. Replies: 6
      Last Post: 29th May 2010, 10:36 AM
    3. fuel rail adaptor plate for aftermarket fuel pressure reg
      By 1sik20valve in forum Cars or Parts Wanted
      Last Post: 5th January 2010, 02:18 PM
    4. fuel pressure
      By cracker in forum Technical - Questions
      Last Post: 25th December 2009, 01:15 AM
    5. Fuel pressure reg?
      By Sparkle86 in forum Technical - Questions
      Last Post: 3rd November 2007, 07:23 PM
