Results 1 to 2 of 2
Thread: Fuel "check valve" in line? Some clarification?
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Default Fuel "check valve" in line? Some clarification?
    TO REMOVE ADS, PLEASE
    REGISTER OR SIGN IN
    Whenever my 4A-GE powered KP61 sits for a while, it takes several seconds for it to start up. The engine spins without the engine starting. When it does start, it sputters for another moment, like all of the gasoline has drained back into the fuel tank. Is there some sort of a check valve in the system? Is there something I need to ad to mine? (My engine and F.I are stock early AE86 parts. I have an aftermarket fuel tank and lines.)
    Can anyone describe to me what failed component I have? If any. Maybe with a photo....
    Thanks
  • #2
    Jan 2015
    Michigan
    South Lyon
    USA
    REGISTER OR SIGN IN
    The stock Toyota fuel pump has a built in check valve, to prevent drain back in the fuel system. My guess is that you have particles in fuel pump check valve seat area preventing a good seal. l would just crack the fuel line connection at the injector manifold first, to verify that you have loss pressure before jumping in and removing the fuel pump. Which is a real PITA. It could be the cold start injector or sensor. Davew7
  • Similar Threads
    1. Valve springs "wanted"
      By apah in forum Technical - Questions
      Last Post: 7th October 2012, 01:48 PM
    2. "Out of memory on line 13"
      By Jonny Rochester in forum Bug Tracker
      Last Post: 31st July 2011, 01:30 PM
    4. Replies: 5
      Last Post: 10th May 2009, 11:35 AM
