Results 1 to 9 of 9
Thread: Silvertop itbs and velocity stack hardware. 95mm 75mm QLD
    West
    Default Silvertop itbs and velocity stack hardware. 95mm 75mm QLD
    Hi team,
    Im no longer running silver-top quads on the 2azfe so Im selling the silver-top itb bits I have as I no longer need them.
    I have a silver set of cnc techno toy tuning trumpets for sale, 75mm as stated to suit silver-top ae101 20v itbs. $165.
    Set of sam q Rolled interference fit trumpets, they out performed the TTT ones on the dyno, have bigger bell mouths and are 94mm long. $165.
    I have a near new silver-top TPS sensor, that I bought only for testing and used for about 12 months. $140. Paid over 200 from sam q. Genuine parts.
    Have a set of silver-top itbs spaced wider apart than standard with modified linkages, mods by sam q. Suit up to 100mm centres between bores, could suit anything that needs wider spacing.
    $300 with the original working tps still attached and throttle pull linkages also.
    Phenolic gaskets to suit silver-top ITBS, insulate the heat from the manifold - $30 a set of 4.
    MRP trumpet clamp bases. CNC clamp bases suit silver-top, they let you buy your own stack from JNT and make custom trumpets to your own specs - $80 for set of 4 with hardware.
    Hit me up, in Brisbane, on 0416 193 936. Would trade for the right set of 15x7s. I need spare wheels, I like fins or something with a similarly classic steez for ae86.
    Glenn
    North Ringwood
    what about some te37 rays
    West
    What size and offset glenn?
    West
    Saw your add sick wheels but out of my price range mate.
    Apr 2018
    Kain
    Hope Valley
    Any further details on the ITB's and some pics?
    West
    What would you like to know mate?
    These are the best shots I have to show the longer tabs Sam made between them.
ID:	37842   Click image for larger version.
    Apr 2018
    Kain
    Hope Valley
    Can you confirm the id size?
    I’m in SA and would like to mod a set of quad throttle bodies for my SR20. I’ll need about a 40mm manifold side diameter.
    Would you consider shipping?
    West
    Shippings fine, no problem.
    Manifold outlet is 42.5mm.
    Cheers.
    West
    Bump for a couple of price reductions.
  1. velocity stack length for rhd ae86
    By AlpineFD in forum Technical - Questions
    Last Post: 11th June 2016, 11:14 AM
  2. Blacktop ITBS vs Silvertop ITBS
    By Futo_gt86 in forum Technical - Questions
    Last Post: 29th February 2016, 12:23 PM
  3. Beams velocity stack length tuning
    By Tim.duncan in forum Technical - Questions
    Last Post: 26th July 2012, 12:32 PM
  4. Silvertop velocity stacks.
    By LittleRedSpirit in forum Cars or Parts Wanted
    Last Post: 29th March 2010, 12:49 PM
  5. 20v silvertop Velocity Stacks
    By 68-evets in forum Cars or Parts Wanted
    Last Post: 5th August 2008, 07:44 PM
