Results 1 to 4 of 4
Thread: 4A-GE banjo bolt question
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Default 4A-GE banjo bolt question
    Does anyone know offhand what size the banjo bolt fitting is an an '86 "big port" Bluetop on the line going INTO the fuel rail from the fuel filter?
    I'm replacing my fuel lines with AN6 fittings and braided line in 3/8" from front to back and I want to have everything ready. I've seen fittings from 12mm and 12.5mm to 18mm.
    This is for my KP61 and currently it has fuel lines from 1/4" to 5/16" and some of it is 3/8"....It's a real mess.
    That banjo going into the fuel rail looks pretty big. But I haven't yet removed it.
    Thanks.
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I just did a thread search and it seems like it's a 12mm x 1.25. So I'll order a 12mm banjo with crush washers and use my stock bolt? That is , unless someone corrects me on the size....
    It looks bigger than that.
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Finding a 12mm metric banjo might be a problem. I've seen set ups with the stock banjo bolt used and a AN fitting brazed on to the end so the AN hose could attach while still retaining the fuel damper. davew7
  • #4
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Thanks Dave.
    As ALWAYS!
    I found a correct size (if it is correct) banjo from Russel fittings via Ebay with the AN6 end and washers.
  • Similar Threads
    1. Replies: 1
      Last Post: 10th September 2015, 08:25 PM
    2. WTB: Oil Squirter Banjo Bolt(s) or 4AGE block containing them!
      By freddo__1 in forum Cars or Parts Wanted
      Last Post: 1st June 2014, 03:35 PM
    3. adm t50, x member, banjo line
      By ae71ness in forum Car Parts For Sale
      Last Post: 29th September 2010, 11:10 PM
    4. 4age bigport Banjo bolt fuel rail size??
      By Prewer in forum Technical - Questions
      Last Post: 23rd January 2010, 07:24 AM
    5. WTD: banjo fitting for oil cooler. ae92
      By Nic19 in forum Cars or Parts Wanted
      Last Post: 16th May 2009, 11:34 AM
