Results 1 to 3 of 3
Thread: JDM bigport wiring diagram
    Nov 2017
    Alano
    Fremantle
    Default JDM bigport wiring diagram
    I've recently purchased a JDM 4age out of a jdm halfcut.
    I've realised now that the wiring diagram will be different from the adm/usdm/eudm and the only one I can find is all in Japanese, would anyone have one laying around with English translations.
    It's a 3 rib TVIS JDM 4age bigport (blue top I believe).
    Would it perhaps be simpler to just install carbs instead? (if this is the case how much of the wiring do I need to get rid of? I havent look a lot into carbs and if anyone has very simple explanation when it comes to wiring for it that would be swell)
    Also the engine has the power steering pump and belt and the engine is going into a adm 4ac ae86 which doesnt have power steering (so ill delete it from the engine) and I cannot find the right belt online for the engine without power steering, what are my options? Would removing the power steering effect the wiring at all??
    Thanks any reply will be appreciated
    West
    Power steering can be deleted by removing the pump, reservoir, and lines. I dont believe there is any wiring that will affect running of the car.
    Carbys are their own source of problems, just different problems to efi problems. I would try to do the wiring and keep it efi for reliability, unless you want to wildly modify it in future, in which case an aftermarket standalone ecu would be best, but more costly and much harder to install than a stock ecu, as you dont just have to wire it, but tune it also.
    Theres a few kinds of carbys people use, webers, dellortos, fcrs. You can buy manifolds for each online if you search for bigport carb manifold, but then you need some carbs, and they really should be tuned by someone who knows their stuff. Personally I think the wiring of efi is more fun than the jetting of carbs.
    Plenty of folks on here are pretty experienced with wiring up a bigport, so just ask the right questions and you will get good answers.
    Mt Macedon
    Any wiring diagram for a 4AGE AE86 should be fine. They are also at the back of the big green book (Toyota body manual). With this info you should be able to wire it fine. While it is personal preference, I would just wire the engine you have rather than change to carbs to avoid it. They bring their own problems and challenges.
    A very rough idea of wiring:
    - The wires in the big plug clipped to the middle of the firewall will need to be disconnected from the 4AC and reconnected to the 4AGE. These are starter signal, oil pressure for gauge, water temp for gauge, etc.
    - Alternator wiring will need to be changed to remove the external regulator and use the internal regulator on the 4AGE (it's like 3 wires).
    - Connect various wires to the ECU, mainly constant power, switched power, earth and just a couple from the rest of the car.
    - Fit and wire an EFI fuel pump. Control it with a circuit opening relay or similar.
    Then enjoy your newly 4AGEd car. It might seem hard initially, but a few hours working through the car and motor wiring diagrams will make it much easier.
  • Similar Threads
    1. BT & ST wiring diagram?
      By HACHI - 6X in forum Technical - Questions
      Last Post: 3rd March 2009, 12:10 AM
    2. 4AC WIRING DIAGRAM
      By loc33e in forum Technical - Questions
      Last Post: 29th March 2008, 07:47 PM
    3. need wiring diagram for mtx-8
      By shaun2 in forum Technical - Questions
      Last Post: 15th July 2007, 01:31 AM
    4. wiring diagram for ae101 4A-GZE
      By lewwy in forum Technical - Questions
      Last Post: 2nd April 2007, 02:40 PM
    5. 4ac wiring diagram
      By wideslider in forum Technical - Questions
      Last Post: 27th May 2006, 09:26 PM
    Tags for this Thread
