Results 1 to 5 of 5
Thread: A terribly seized axle
    Jul 2018
    Ryka
    CA
    OAKLAND
    United States
    Question A terribly seized axle
    Hi new member here,
    First time posting so im hoping i dont screw it up.
    i have a 1986 gts corolla. Im trying to take my rear axles out so i can drop the diff, and take it to a guy to get it rebuilt. Ive taken out the right axle but the left axle is stuck inside the housing. Ive tried to heat up the bearing housing with a torch. Ive been trying to use a slide hammer. Ive used almost a whole bottle of PB blaster in 3 days. i put on a trash wheel backwards, and hit it with a sledge hammer. My strong russian homie came over to try swinging the sledge hammer at the slide hammer. also ive drained the diff and tried to spray it, and the axle with PB blaster during all of this. Ive also tried a couple other little things that may or may not have helped. I have no clue what to do at this point. Im starting to feel depressed because i cant come up with a solution.
    Please help me.
    Thanks,
    Ryka M
    Last edited by 4aGinme; 12th July 2018 at 06:07 PM. Reason: spelling/grammar errors
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Is it an LSD rear end?
    I think the limited slip diff has a clip inside and not just the retainer plate inside the back wheel housing. But I'm not positive.
    Have you looked an an exploded view picture of the diff? Maybe on a Toyota parts site?
    Hopefully someone will be along soon that can say whats going on for sure.
    Jul 2018
    Ryka
    CA
    OAKLAND
    United States
    yes my car did some with an LSD. Thats what i thought too, but if that were the case the right axle would never have come out.
  • #4
    West
    There's no clips it should come apart if the flange bolts are undone and the caliper and disc is out of the way. Maybe heat the casing after freezing the axle itself, reverse interference fit to give looser tolerances, then go hard with the slide hammer. Whack it in a couple of times then out to free it up. Or simply heat it till its red hot and try again.
  • #5
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    After you get the axle out, but before pressing on a new bearing have a machine shop verify that the axle flange has not been bent from all the hitting. If you have a dial indicator you could check run out yourself. The face may need a surface cut to true up the mounting flange. Don't ask how I know. Davew7
  • Similar Threads
    1. Seized cambertops
      By ae86 in forum Technical - Questions
      Last Post: 20th October 2011, 05:24 PM
    2. WTB: T18 axle
      By TOY3TG in forum Cars or Parts Wanted
      Last Post: 21st April 2010, 10:10 PM
    3. Axle
      By Figgy in forum Technical - Questions
      Last Post: 10th December 2009, 05:30 PM
    4. Engine won't turn over, seems to be seized.
      By PULSE in forum Technical - Questions
      Last Post: 2nd September 2008, 04:43 PM
    5. panhard rod is seized up to the max
      By sprinters_r_mad in forum Technical - Questions
      Last Post: 18th July 2008, 02:10 AM
