Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: HARD brake pedal question
  1. #11
    West
    TO REMOVE ADS, PLEASE
    REGISTER OR SIGN IN
    Could also be caliper related, ae86 manual suggests a stuck piston, the way to see would be drive it and after it happens for a bit stop and see which brakes are hot.
  • #12
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I did that with a laser thermometer and all of the brakes were hot. None remarkably more than the others, rotors and drums on each side.
    Also, I've since replaced the calipers and rear brake wheel cylinders.
  • #13
    West
    When you rebuild the drums its possible to put the adjuster in backwards and create a system where the drums tighten and not retract with every use. But that would just drag the rears.
    Bloody strange. I think on drum cars they proportioning valve is more of a pressure limiting valve, it should not be able to create the problems you are experiencing.
  • #14
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    Well. The new master that came is completely WRONG!
    SO, I'll have to wait and see....
    I've been looking at the adjustment on my old booster. It is adjustable. But looks like a real P.I.T.A.
    Nice information about the proportioning valve not causing symptoms like I have. I wont me so with it then.
  • #15
    Veteran Konakid's Avatar
    Henry
    Eastern
    It will be the brake pedal freeplay adjustment. If there is not a few mm freeplay then the brakes will lock on after driving due to the fluid getting warmer after a few stops and expanding. Have had this happen to me before. add another 1 or 2mm to the pedal freeplay and try again.
    RT142 Estate.
    AJPS.
  • #16
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I just got the new parts.
    When I placed the "OLD" master and booster together, outside of the car, I could see that when i pushed the master up flush with the booster, the pedal rod pushed back just a hair....So NO free play and some drag.
    Same with the new parts. So I was able to adjust the rod on the booster before I assembled the master for a few MM of free play.
    It's all assembled, but it's been too hot outside to finish the project. Maybe i'll get it bled out today.
    I understand about the brakes dragging. But would that also make for a hard pedal?
    I have good vacuum. I started the engine and ran it for a minute or two. Then about half an hour later, yanked off the vacuum tube from the booster and I heard a WOOSH. Vacuum was still there.
  • #17
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    REGISTER OR SIGN IN
    I replaced the master with another rebuilt one and I did another complete brake bleeding of all fluid. I backed off the booster push rod one full turn and made a tiny bit of free play. Re-assembled everything and......Hard brakes still!I replaced the booster vacuum line with more reinforced vacuum tubing, thinking that the line might be sucking in, and I tested the manifold vacuum at the manifold and the booster. Almost 18.The last thing I did out of despiration was to blow air into the vacuum port of the booster instead of vacuum (something sticking?) and shot some WD40 into the port as well.Now the booster works....just a little. But enough to tell me that my rebuilt booster sucks!
  • Page 2 of 2 FirstFirst 1 2
    1. Question! Hard race tie rod end
      By Anthony86 in forum Technical - Questions
      Last Post: 1st February 2017, 07:36 PM
    2. brake pedal gone hard/pressure on pedal
      By jmae86 in forum Technical - Questions
      Last Post: 2nd April 2013, 03:26 PM
    3. Quick question: adjustable pan hard rod
      By Bozu in forum Technical - Questions
      Last Post: 16th June 2011, 05:00 PM
    4. Adjustable pan hard rod question
      By vivioman in forum Technical - Questions
      Last Post: 13th March 2009, 12:18 PM
    5. Question...Are 2 door xE7x hard to find out there?
      By MarkAE86 in forum Technical - Questions
      Last Post: 3rd March 2009, 04:46 PM
