Originally Posted by
LittleRedSpirit
I found it easy to buy steel bundy tube with copper coating and to bend up new ones. Its about a hundred bucks worth of tooling, for the cutter, bender and flaring tool, and then you can make endless amounts of new lines in various sizes. Id prefer that over anything flexible considering all oem uses rigid lines. You should be able to find a shop in your area that deals in industrial fittings and will have all this stuff. There's a great shop in Brisbane called IFS, Industrial Fittings Sales, if you get stuck.
Hard pedal could be as simple as a bad booster. I know you have manifold vacuum, but have you checked that the one way valve works and that the booster functions with the test procedure in the manual? The OEM manual also should have pedal height specs.
