Results 1 to 6 of 6
Thread: Fuel System - Surge Tank Running Empty
    Jul 2017
    Gareth
    Western Australia
    South Guildford
    Default Fuel System - Surge Tank Running Empty
    Hi Guys
    I have an issue with my car where the surge tank runs empty which of course makes the engine die.
    Car: MK1 Ford Cortina
    Engine: 4AGE Blacktop with stock ECU
    Fuel System: Goss GE239 lift pump, 2L surge tank, Bosch 044 fuel pump, 10mm feed line, 8mm return line. There is a element filter before the lift pump, an efi filter after the Bosch.
    This issue has been happening for a while, It drives sweet for half an hour or more then will run out of fuel e.g. the surge tank is empty. I was running a carter black lift pump and it had the same issue.
    Does anyone have any theories of what the cause could be?
    Mt Macedon
    How are the fuel lines plumbed?
    Usually the return line from the rail should return to the surge tank. If this goes straight back to the fuel tank then you may empty the surge tank if your EFI pump is larger capacity than your lift pump.
    If the return line is already to the surge tank then my only guess is that the lift pump is not up to the task. Either too small, blocked lines, pickup dodgy/kinked/blocked screen, or maybe that it is sucking air somehow and losing its prime. Funny how it only turns up after half an hour.
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    My guess is that you are loosing fuel pressure as the pump heats up from running. Is it possible to plumb in a pressure gauge verify. Is it possible to improve the cooling of the pump. DaveW7
  • #4
    West
    I agree with hen, its likely a plumbing issue. If the return doesn't go into the surge tank it will usually run dry. In theory you can have a lift pump that moves half as much fuel as the efi pump as the return will always bring the vast majority of fuel back to the surge tank from the rail. The minute amount that gets burned compared to total flow is not enough to affect the filling of the surge tank if it returns to it. In this instance the lift pump needs only to supply as much fuel as the engine actually consumes.
  • #5
    http://www.ae86drivingclub.com.au/fo...urge-tank-KE70
    Good writeup of installation of the surge tank.
  • #6
    Jul 2017
    Gareth
    Western Australia
    South Guildford
    Thanks for your help guys. I ended up fixing the problem by moving the lift pump closer to the fuel tank.
  • Similar Threads
    1. Replies: 2
      Last Post: 10th October 2011, 10:12 PM
    2. Fuel system, Surge tank, Fuel pump ect
      By stixy in forum Cars or Parts Wanted
      Last Post: 19th February 2011, 03:23 PM
    3. WTB Surge tank system
      By E7 in forum Cars or Parts Wanted
      Last Post: 3rd March 2008, 05:03 PM
    4. for sale , surge tank, aus fuel tank, hood linning + more
      By hillclimb86 in forum Car Parts For Sale
      Last Post: 20th June 2007, 12:20 PM
