Hi Guys
I have an issue with my car where the surge tank runs empty which of course makes the engine die.
Car: MK1 Ford Cortina
Engine: 4AGE Blacktop with stock ECU
Fuel System: Goss GE239 lift pump, 2L surge tank, Bosch 044 fuel pump, 10mm feed line, 8mm return line. There is a element filter before the lift pump, an efi filter after the Bosch.
This issue has been happening for a while, It drives sweet for half an hour or more then will run out of fuel e.g. the surge tank is empty. I was running a carter black lift pump and it had the same issue.
Does anyone have any theories of what the cause could be?
