Results 1 to 6 of 6
Thread: 4AGE Exhaust Size
    Member tristybomb's Avatar
    Tristan
    Default 4AGE Exhaust Size
    Hello everyone, this topic has probably been talked about before but I'm currently looking into getting a exhaust made for my AE86. I've recently installed a built 4AGE Big Port! Hi comp pistons, Big Cams! Porter head and ITB's. I already have the headers for it. What size and set up would you'd recommend? Thanks
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Assuming it's a street machine, I would think you should be looking at an exhaust system that is 2 1/4" Dia. [56mm]. The 2 1/4" Dia. is going to be pretty loud, and a 2 1/2" Dia. system is really loud, you would end up a hand full of tickets. Davew7
    Tristan
    Hey mate yeah the is going to be used for hill climbs, Sunday drive ect as it has si rego on it. I was thinking 2'1/4 aswell with just a muffler at the back
  • #4
    West
    I always used to run 2 and a quarter press bent exhausts on a street driven 4age car. Keep it steel its a bit quieter. I had 4-2-1s, then a cat, resonator and 1 small muffler, it wasn't too loud, until one day I broke it behind the resonator and it was super loud.
  • #5
    Senior Member ae86 drifter's Avatar
    Pete
    being a built hi comp motor 2 1/2 would be the way to go. you don't wanna choke it going to small. As for loud add a muffler before the diff and after..
    ROYAL GARAGE NEWCASTLE
  • #6
    2.25 mandrel or or 2.5" press is what i'd be running if the motor is high comp.
  • Similar Threads
    1. exhaust size for a smallport 4age
      By ae_86_jp in forum Technical - Questions
      Last Post: 24th August 2011, 12:05 AM
    2. exhaust size
      By bart in forum Technical - Questions
      Last Post: 6th August 2008, 10:47 AM
    Tags for this Thread
