Results 1 to 3 of 3
Thread: Roll Cage Question
    Senior Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Roll Cage Question
    Hellos,
    Would it be overkill for a 6-point roll cage in a 1uz swap KE70 to weigh 40kg? ...
    How much do your cages weigh? what would you recommended?
    cheers.
    Nov 2018
    Joel
    Qld
    It's pretty easy to work out how much a cage should weigh by measuring the linear metres of tube, the OD and the wall thickness (can measure with ultrasonic thingy) or ID and working then out the volume of steel. Then multiply the volume by the density of steel. The density of chrome moly is almost exactly the same as mild steel. Add a couple of percent for gussets, tabs, footings and filler wire/rod.
    40kg is in the ball park.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Quote Originally Posted by Shit Tin Sprinter View Post
    Thanks for the reply. I did the math and total weight will be approx 43kg, which is ~94 lbs also equivalent to a 10hp loss or 0.3 seconds off the pace.
    Not so bad I guess.
  • Similar Threads
    1. roll cage
      By talbo in forum Cars or Parts Wanted
      Last Post: 17th April 2012, 08:48 PM
    2. AE86 / KE70 (sedan) Roll Cage - 7pt, half or full cage
      By Bomfunkmc in forum Car Parts For Sale
      Last Post: 17th April 2012, 12:27 AM
    3. wtb: Roll cage!!!
      By stanzzza in forum Cars or Parts Wanted
      Last Post: 12th July 2010, 07:31 PM
    4. Wtb: Roll cage!!!
      By schmykel in forum Cars or Parts Wanted
      Last Post: 5th June 2010, 10:28 PM
    5. 1/2 roll cage
      By SSD20V in forum Technical - Questions
      Last Post: 27th July 2009, 06:18 PM
