Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Brake booster delete thoughts
  1. #11
    Eddie
    Default Brake booster delete thoughts
    Pedal box. Will post a pic later. Added bonus of giving miles of room for trumpets. You will need a smaller master as Hen has noted. I'm running 5/8" fronts with 3/4" rear. The rear is slightly too large but I had a couple of that size spare. Hoping I can tune it out with the balance bar. Brakes are Brembo all round. 4 pot fronts 2x40mm and 2x46mm pistons. Rears are 2x40mm.
  • #12
    Feb 2018
    EDWARD
    FL
    SUNRISE
    United States
    I'm not sure what was wrong. But blowing out all the lines and junctions as well as the proportioning valve fixed it.
    Now the only issue is a small one. The pedal play is almost 1". I've got to get my fat ass back under the dash and re adjust that brake pedal. I can stop now. The pedal travel is just too long.
    How much free play should there be? I'm thinking 1/4"? Whatis that? 8mm?
  • #13
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    The correct push rod clearance at the master cylinder is 1mm between the push rod and the M/C internal piston. That should give you about a 1/4 to 3/8" free travel at the pedal.
    Note you MUST have clearance between the push rod and piston to allow brake fluid to return. Davew7
  • Page 2 of 2 FirstFirst 1 2
    1. ADM Brake Booster
      By wideslider in forum Cars or Parts Wanted
      Last Post: 16th September 2012, 09:41 PM
    2. BRake Lines - Brake Booster One-Way valve
      By bigm in forum Cars or Parts Wanted
      Last Post: 29th January 2010, 06:56 AM
    3. brake booster
      By Mr Fujiwara in forum Technical - Questions
      Last Post: 17th September 2008, 08:20 PM
    4. brake booster or no booster?
      By slippry in forum Technical - Questions
      Last Post: 29th April 2008, 11:41 AM
    5. brake booster
      By starni_boy in forum Technical - Questions
      Last Post: 11th February 2007, 05:52 PM
