Results 1 to 2 of 2
Thread: Half way thru Ls1 into ke70 but having issues...few questions need advice also :)
    Nov 2018
    Jason
    Sa
    Default Half way thru Ls1 into ke70 but having issues...few questions need advice also :)
    Hi guys, Iím new here
    Iím about half way thru my Ls1 6speed ke70 high top wagon sleeper build and have a couple issues I need some help with....
    Firstly cable clutch to hydraulic clutch... Iíve modified a commodore manual pedal and fitted it BEFORE I put the motor back in :s and itís never gonna clear the engine so back to the drawing board... anyone know of a setup that will work either inside or outside the cab?
    Secondly... what steering racks can be fitted with little to no modifications? I want power steering and at the same time want to shift the steering rack shaft over to clear the starter motor because I canít justify paying $1000 for a starter relocation kit
    I appreciate any suggestions you may have or knowledge you can share .. thanks guys
    Use the std commodore clutch setup, but adapt it to suit your ke70 peddle.
    As for the steering rack, either mount the motor off center or adapt something to work or spend the $$$$ on the relocation kit
  • Similar Threads
    1. Steering issues! Bump steer etc!!! Advice?!
      By Ade_Mc in forum Technical - Questions
      Last Post: 24th December 2012, 02:55 PM
    2. your advice to buy a front half cut. (brisbane)
      By ballos in forum Brisbane & QLD Events and Discussion
      Last Post: 1st June 2011, 12:53 PM
    3. Ignition issues. Just need to know 2 questions!
      By Dave in forum Technical - Questions
      Last Post: 6th May 2011, 10:33 AM
    Tags for this Thread
