Hi guys, I’m new here
I’m about half way thru my Ls1 6speed ke70 high top wagon sleeper build and have a couple issues I need some help with....
Firstly cable clutch to hydraulic clutch... I’ve modified a commodore manual pedal and fitted it BEFORE I put the motor back in :s and it’s never gonna clear the engine so back to the drawing board... anyone know of a setup that will work either inside or outside the cab?
Secondly... what steering racks can be fitted with little to no modifications? I want power steering and at the same time want to shift the steering rack shaft over to clear the starter motor because I can’t justify paying $1000 for a starter relocation kit
I appreciate any suggestions you may have or knowledge you can share .. thanks guys
Use the std commodore clutch setup, but adapt it to suit your ke70 peddle.
As for the steering rack, either mount the motor off center or adapt something to work or spend the $$$$ on the relocation kit
