Results 1 to 6 of 6
Thread: Idle control 20v
    Jun 2011
    bazz
    nsw
    sydney
    Default Idle control 20v
    Hi all trying to adjust the setting for a st 20v using an old haltech (BAC)
    Anyone have anyone know the frequency? Or settings?
    What model haltech are you running, i know the sprint 500's can't control the idle stepper motor properly.
    If you give haltech a call, they'll support you on the phone, every ecu sold comes with support.
    Jun 2011
    bazz
    nsw
    sydney
    Itís an older e8. Last time I sent them an email they pretty much said that itís a prehistoric ecu and they donít make parts etc anymore. Donít think theyíll be much help.
    The guy who had the setup wasnít running it. So Iíve added it to the build.
  • #4
    Mt Macedon
    Is the 20V ISCV like the ZE? Three pin, with 12V in the middle and an "open" wire and a "close" wire?
    If so then I have a diagram for a circuit that will convert a single PWM wire into two signals for the "open" and "close" wire. I may even be able to dig out the parameters I used to control the ZE idle.
  • #5
    Jun 2011
    bazz
    nsw
    sydney
    Yeah thatís correct. Low 12v and high. Iíve wired it in with 2 pwr and a 12v. Itís just the frequency and settings Iíd be really greatful for
  • #6
    Mt Macedon
    Just dug out some old maps (from Wolf 3D V4). Not really sure it'll help. The frequency I have set to 150. But I think that may not be in a useful unit, but just a value between 0 and 255. In any case, you can just try varying the frequency until the buzzing isn't annoying, and the valve still works as desired.
    None of the other parameters I have seem to match what the Haltech requires. So not much more help from me I'm afraid. However, looking at the parameters it shouldn't be too hard to get it up and running. Ignore the post-start and aircon initially. And just play with the others one at a time til you understand how they work and can get a good combination. Also remember that you have a "dumb" air bypass screw I assume too, which lets you set the base idle, then the ISCV adjusts from this start point.
  • Similar Threads
    1. 1G-GTE Idle speed control valve
      By CraigMX73 in forum Cars or Parts Wanted
      Last Post: 25th September 2014, 12:23 AM
    2. WTB: idle control valve smallport 4ag
      By wt86 in forum Cars or Parts Wanted
      Last Post: 1st November 2013, 09:19 AM
    3. WTB: aw11 gze idle control valve
      By mistr2 in forum Cars or Parts Wanted
      Last Post: 22nd January 2009, 06:54 PM
    4. 4age idle control motor
      By lewy in forum Cars or Parts Wanted
      Last Post: 11th March 2007, 08:37 PM
