Results 1 to 2 of 2
Thread: RA60 Notch
    Junior Member ZZZTOP's Avatar
    Aug 2016
    Zane
    Qld
    Default RA60 Notch
    TO REMOVE ADS, PLEASE
    REGISTER OR SIGN IN
    Big fan of build threads so thought id start one for my new project.
    Mid last year i bought this beautiful machine after hunting for a celica notch back for a few years.
    1982 Celica RA60 1 owner
    427,000 on the clock
    Two small bits of rust and a flogged out 21r
    Car was standard and had been well looked after before sitting for a few years. It was a perfect base to build from.
    Over the next 6 months i bought nearly everything to overhaul the suspension and brakes and ummed and ahhh'd about a powerplant for this 1980s stallion. An unfortunate incident driving a friends car saw a naturally aspirated sr20 thrust into my possession so i thought may as well go with that.
    Im a big fan of NA engines and know my way around nissan's enough to be confident wiring it in and setting up myself. The car will be drifted so non turbo will keep things cheap. Plans for the motor are to replace the bearings, oil pump, water pump, some gaskets and throw on some headers. Later down the track id like to do something more but for now i just want to drive the car.
    Bought an ra65 parts car with a friend.
    Which means ive now got the nice front end to go on as well as some spare parts.
    I have only recently started working on the car so should have plenty to update over the coming months. Im planning to have the car on the road before i go to japan in late July so ive got a fair bit to do. Here are some pictures.
ID:	38024Click image for larger version.
ID:	38025Click image for larger version.
ID:	38026Click image for larger version.
  • #2
    Aug 2016
    Zane
    Qld
    REGISTER OR SIGN IN
    Been a while, car is getting close. Got the SR20 and box bolted in. Currently getting exhaust and tailshaft made.
    Also had a trd LSD installed.All new bushes in the rear, adjustable panhard rod, whiteline swaybar and ae86 coilovers in the rear.
ID:	38210Click image for larger version.
ID:	38211Click image for larger version.
    Mx73 coilovers with 8kg springs welded to factory spindles in the front. Rebuilt brakes, RCA, new rack ends and tie rods from an mx73, extended lcas from xt130 and custom knuckles for a bit of lock. Will need a bit of a roll to fit the 7.5-2 on the front.
    Have a full set of MK1s in 7.5 +0 and 8 +0 to go on when i get the car back.
    And here is a picture of how it sits in all its dusty glory (height was jacked to get it on the trailer). Still need to swap to the ra65 front lights, finish wiring in the motor, run some hoses and then it should run.
    Very excited to drive this, looking forward to trying out some circuit racing/hillclimb and possibly some rallycross.
  • Similar Threads
    1. N Style notch.
      By drift kid in forum Toyotas in the Media
      Last Post: 26th April 2014, 03:11 AM
    2. notch back
      By MR. iNFMS in forum Cars or Parts Wanted
      Last Post: 14th April 2010, 04:53 PM
    3. WTB: AE86 notch.
      By BoostedTG in forum Cars for Sale (Toyota Only)
      Last Post: 10th June 2008, 11:36 AM
    4. NOTCH BOOTLID
      By shinobi in forum Cars or Parts Wanted
      Last Post: 12th April 2008, 07:52 PM
