Results 1 to 3 of 3
Thread: Strong Fuel Smell - Blacktop 4AGE
    Jul 2017
    Gareth
    Western Australia
    South Guildford
    Default Strong Fuel Smell - Blacktop 4AGE
    Hi Guys
    I have completed a Blacktop 4AGE conversion into my MK1 Cortina and am very happy with it. However there is quite a strong fuel smell inside the cabin when driving.
    I have a Carter black lift pump to a 2L surge tank and a Bosch 044 fuel pump with a return line to the fuel tank. As much as possible I have aluminium fuel lines with rubber hose only for connections.
    The car is old but in good condition, i have sealed up as many of the holes in the firewall as I can
    Any theories on what might be causing this fuel smell issue?Click image for larger version.
    Jonathan
    Fuel will slowly go through rubber hose. For EFI you need this spec fuel hose at a minimum: SAE 30 R9, and SAE 30 R10 for anything submersed inside the tank. If you use R6 hose, that is not good enough for EFI supply hose, but will probably be fine for return hose.
    The gold standard is PTFE (teflon) covered in wire braid, and AN fittings. Done properly the PTFE shouldn't leak as much smell as a rubber hose.
    Or, just seal the boot from the passenger compartment better.
    Mar 2011
    Ali
    Weren't you having a problem with it emptying the surge tank? is the main tank venting properly?
  1. 4AGE Blacktop Fuel Line
    By slinky1337 in forum Technical - Questions
    Last Post: 30th March 2014, 10:33 PM
  2. what does your car smell like?
    By dove grey 64 in forum General Topics (No Technical Questions)
    Last Post: 24th February 2014, 08:58 PM
  3. ADM AE86 (Blacktop) - Fuel Tank ?
    By 73ta22 in forum Technical - Questions
    Last Post: 21st August 2009, 02:10 AM
  4. Rattling / Strong Fuel smell
    By RolandGTV85 in forum Technical - Questions
    Last Post: 2nd June 2006, 08:41 AM
  5. Bad Smell
    By hara_kiri in forum Technical - Questions
    Last Post: 5th December 2005, 08:41 AM
