Results 1 to 8 of 8
Thread: Adaptronic > Innovate MTX-L connectivity issues
    Senior Member shawn_26's Avatar
    Shawn
    Southside
    Default Adaptronic > Innovate MTX-L connectivity issues
    Hoping someone with good Adaptronic knowledge can help out here.
    Had my 20V 86 tuned this week in Melbourne. Makes good smooth power, 125hp at the wheels. But the tuner (and myself) could not get my Innovate MTX-L to communicate to the ECU (e420d). The actual gauge displays AFR, but no data is being transmitted to the ECU.
    Nothing is displayed on the Lambda graph in Eugene, and no TX/RX lights on the 'serial in' port of the ECU.
    Connected with the 4pin molex to 2.5mm serial cable, settings in Eugene as per Adaptronics instructions. Am I missing something? Faulty cable? Faulty 'serial in' on the ECU? I really want to be able to enable 'closed loop' for daily driving.
    Thanks,
    Shawn.
    Senior Member Dylan's Avatar
    Dylan
    Just to confirm ,the serial cable from the ECU is connected to the SERIAL OUT connector on the gauge.
    Shawn
    Southside
    Yeah, correct. Ive tried both connectors on the back of the gauge.
    Still nothing coming up on Eugene.
  • #4
    West
    Use wari, its better for the old ecus, Ive found. See if that helps. What firmware is on the ecu? Use the version of wari that goes with it.
  • #5
    West
    Have you selected it on the correct tab in the software? Not seeing any gauge input on f2 window? Takes 20 or 30 seconds to warm up, and then you should have your reading. Try f11 and see if theres a voltage showing on its input.
  • #6
    West
    Failing that I think you can hard wire it to ecu if youre worried about the serial connectors.
  • #7
    Shawn
    Southside
    Cheers for the response.
    I was suspecting it could be a firmware issue. Can I download different versions of WARI to suit?
    And I've selected all the ECU settings as per:
    https://adaptronic.zendesk.com/hc/en...daptronic-ECU-
  • #8
    Shawn
    Southside
    Solved...turned out to be a firmware / connectivity issue. And yes, WARI works much better with 'Select' ECU's.
    Cheers for the responses.
  • Similar Threads
    1. FS: MTX-L Innovate wideband sensor kit
      By DR86FT in forum Car Parts For Sale
      Last Post: 10th October 2015, 11:18 AM
    2. Innovate Motorport LMA3 (multiparameter datalogger) $175 [WA]
      By Ghetto-Spec .:bayka:. in forum Car Parts For Sale
      Last Post: 6th September 2012, 11:57 PM
    3. Innovate Lc-1 Wideband 02 Sensor
      By Vaughn in forum General Topics (No Technical Questions)
      Last Post: 5th September 2011, 09:13 PM
    4. Replies: 1
      Last Post: 22nd August 2011, 06:34 PM
    5. Adaptronic issues
      By gaffa in forum Technical - Questions
      Last Post: 13th October 2009, 06:27 PM
