Results 1 to 2 of 2
Thread: 4age 16v idle control valve
    Member tristybomb's Avatar
    Tristan
    Default 4age 16v idle control valve
    hey everyone ive got a built 4age 16v with 20v ITBs on it and was wondering what people have done to setup a idle control valve. i'm using a haltech sprint 500 witch dosent support the idle function, but has anyone got around this?
    Jonathan
    As you now know, you can't use the idle control valve unless you use the matching stock ECU, or a good ECU that can control the valve. If the Haltech 500 can't do it, then you can't control a idle valve.
    Instead, you need to bump the idle up with the idle bypass screws on each throttle. The correct way to set it up, is to keep the throttle stops in the stock positions, which allows the throttles to close fully shut. Then take off the trumpets, and unwind the air bleed screw for each throttle, about 2 turns each. Make them all even, run the engine to set idle to around 900rpm.
  • Similar Threads
    1. 1G-GTE Idle speed control valve
      By CraigMX73 in forum Cars or Parts Wanted
      Last Post: 25th September 2014, 12:23 AM
    2. 4AGE 16v TVIS Solenoid and Idle Control Valve.
      By Mika in forum Technical - Questions
      Last Post: 18th March 2013, 02:20 AM
    3. Replies: 11
      Last Post: 12th February 2012, 03:57 PM
    4. WTB: aw11 gze idle control valve
      By mistr2 in forum Cars or Parts Wanted
      Last Post: 22nd January 2009, 06:54 PM
    Tags for this Thread
