Results 1 to 5 of 5
Thread: Are Aexx/Kexx/Texx diff pinions Centered or Off-centered?
    Senior Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Are Aexx/Kexx/Texx diff pinions Centered or Off-centered?
    So I tried to square my axle/wheels and I found that in order for the diff pinion to be dead centre [directly inline with the trans yoke], it has to move almost 1 inch to the left.
    Is it my set-up that is bent or did it come off-centered from the factory?
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Infact I was planning to install a 1" spacer on the opposite end just to make the wheels flash on both ends.
    What are your thoughts on this?
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    The axle pinion is off-set by design. If you are trying to center the axle, the easiest method [not the most accurate] is to just measure distance from the fender lip to the tires and compare the sides. To actually adjust the axle, you will have to modify the panhard rod, or get an adjustable rod.
    davew7
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Quote Originally Posted by davew7 View Post
    davew7
    Good to know the offset is by design. I thought something was bent...
    So I did modify the panhard rod and centered the pinion using a laser beam pointer on the trans yoke.
    The left wheel sticks out about 10mm and the right wheel is inside the lip by about an inch.
    Hence the consideration for a spacer.
    Thanks for your reply.
  1. XT130 Coilovers for KEXX
    By Bomfunkmc in forum Car Parts For Sale
    Last Post: 3rd April 2012, 10:25 AM
  2. Ae86 strut tops into TExx chassis
    By Andy San in forum Technical - Questions
    Last Post: 21st June 2010, 11:30 PM
  3. Work Vs xx 17 by 7 +35 and 17 by 8 +22 gold centered. 4 by 114
    By eightsixboy in forum Car Parts For Sale
    Last Post: 22nd November 2009, 12:35 PM
  4. old school speedy gold centered rims $150 neg
    By d1doony in forum Car Parts For Sale
    Last Post: 30th May 2008, 02:11 PM
  5. T series 4.1 and 3.7 ring & pinions
    By jctwincam in forum Car Parts For Sale
    Last Post: 12th June 2007, 09:37 AM
