Results 1 to 8 of 8
Thread: Compression On A 20V
    Default Compression On A 20V
    What compresion should i expect to get on a 20v 4age?
    Veteran shift_rook's Avatar
    SE Burbs
    blacktop or silvertop. completely stock? silvertops have 10.5:1 blacktops have 11:1
    LOL yeh i know that. sorry I shoulda been more clear what reading should I get on the Comp test
    User fantapants's Avatar
    Pat
    i got in the 220's from memory
    shouldnt be a HUGE deal just so long as they are all within a couple of points
    06/07/2011
    180psi-200psi is very good and under is shit mine is 160psi so im just doing a crazy bulid
    SE Burbs
    sorr probably should have read it better, no idea about 20v comp readings
    Senior Member adam's Avatar
    Adam
    Compression numbers shouldn't be a good way of judging whether a motor is healthy or not unless it's completely standard. Going to more aggressive camshafts will affect the compression readings.
    As long as the numbers are all within 5% (?) of each other, it should be fine.
    Edit: Starter motor speed will also effect results.
    cant rely on compression test numbers. using one tester i got 225psi across all four and using another i got 165psi. it gave roughly the same compression through all four but unless your using multiple testers and finding the average you cant rely on the test numbers much.
  1. Compression Test
    By SNAP in forum Technical - Questions
    Last Post: 16th June 2008, 09:56 AM
  2. no compression
    By kaneO in forum Technical - Questions
    Last Post: 27th November 2007, 10:34 AM
  3. Compression ratios
    By Jazz9 in forum Technical - Questions
    Last Post: 17th September 2007, 01:43 AM
  4. compression
    By timmay in forum Technical - Questions
    Last Post: 19th June 2006, 03:43 PM
  5. Any one know what a 20v compression reading is
    By omy in forum Technical - Questions
    Last Post: 7th May 2006, 06:42 PM
