Results 1 to 5 of 5
Thread: Tachometer Technical Questions
    Jun 2020
    Isaac
    Vancouver
    United States
    Default Tachometer Technical Questions
    Hello everyone!
    I have been looking for more specific answers on the tachometer resistor mod when swapping in a 3SGE Beams. I do not have an AE86 but own a RA65 Celica that I am engine swapping in a 3SGE Beams.
    Like both stock engine 4AGE and 22RE, both ran off the ignitor negative terminal for the tachometer signal. I have seen where AE86 guys remove resistor R4 and stick in a 10k resistor in order to use their stock tachometer.
    So my question is, what is R4? And what does it link together, 12v and signal?. Is it possibly to simply add a resistor inline of the tachometer signal or does it have to bridge in between 2 points and what 2 points would that be?
    Thank you for reading, any information helps!
    -Isaac
    Jan 2018
    Juan
    Doha
    Doha
    Qatar
    Hi
    This will work on your car o aftermarket ecu
    Thats on ebay
    Some guys like Azril abu bakar( find it on facebook) are manufacturing some relays that work
    Juan
    Sent from my iPhone using Tapatalk
    West
    West
    On the ae86 you need a pullup resistor. Thats all the little thing above is, you can make one by taking the cap off any relay and zip tieing the contact to disable movement. You will find articles online about wiring this, and some ecu companies have documented the process.
    West
  1. CA18 -> KE70 Technical Questions (S13 Crossmember)
    By ShowUsYourTints in forum Technical - Questions
    Last Post: 20th June 2012, 01:42 PM
  2. Pivot tachometer.
    By starni_boy in forum Car Parts For Sale
    Last Post: 6th April 2010, 11:05 PM
  3. 20v into ae82 tachometer
    By 20vnic in forum Technical - Questions
    Last Post: 21st August 2008, 10:58 PM
  4. GZE and stock Tachometer
    By riojin in forum Technical - Questions
    Last Post: 7th December 2007, 10:55 AM
Tags for this Thread
