Hi Gary, you need the shorter 1.6 / 2.0L type.
You can use an MGB clutch plate if you are using the 200mm flywheel, alternatively Helix can supply a proper motorsport paddle clutch for your application: https://helixautosport.com/catalogues.html
From memory you can use the standard release bearing carrier but it will need to be milled out a bit. The gearlever will be further back. I used a single piece propshaft without issue.
If your bellhousing is not the original RM sport (it will be stamped as such) check that the gearbox/bellhousing mates to an engine before trying to fit it to the car!
