Results 1 to 4 of 4
Thread: Type 9 conversion question
    Jun 2020
    Gary
    Tasmania
    North Hobart
    Default Type 9 conversion question
    Hi all, first post.
    I am looking at getting a Type 9 for my Ae86 tarmac rally car. I am about to get the gearbox built in the UK and the gearbox builder is asking what input shaft length I need? Apparently there are two types as fitted to 1.6/2.0 and slightly longer as fitted to 2.8's I am am guessing 1.6/2.0 but does anyone know for sure?
    Jun 2011
    james
    oxford
    general area
    England
    Hi Gary, you need the shorter 1.6 / 2.0L type.
    You can use an MGB clutch plate if you are using the 200mm flywheel, alternatively Helix can supply a proper motorsport paddle clutch for your application:
    From memory you can use the standard release bearing carrier but it will need to be milled out a bit. The gearlever will be further back. I used a single piece propshaft without issue.
    If your bellhousing is not the original RM sport (it will be stamped as such) check that the gearbox/bellhousing mates to an engine before trying to fit it to the car!
    Jun 2020
    Gary
    Tasmania
    North Hobart
    Thanks!
    Jun 2011
    james
    oxford
    general area
    England
    If you are going Quaife (or similar) ratios they work really well on 13" wheels and a 4.778 Final Drive.
  1. 1980 t130 18r manual conversion question
    By batman.182 in forum Technical - Questions
    Last Post: 4th January 2012, 05:52 PM
  2. GReddy Type-S coilovers - Remote control question
    By maxhag in forum Technical - Questions
    Last Post: 20th November 2010, 04:31 PM
  3. 4ac - 4age 16v bigport conversion alternator question
    By Leigh in forum Technical - Questions
    Last Post: 19th May 2008, 03:04 PM
  4. FC brake conversion question
    By ae86 drifter in forum Technical - Questions
    Last Post: 5th April 2007, 01:25 PM
  5. HID conversion question
    By Beserker99 in forum Technical - Questions
    Last Post: 14th May 2006, 01:09 AM
