for sale my 7age setup
rwd manifold (smallport)
7age engine (7afe bottom end with 16v small port head and big port cams)
has dizzy and most bits and peices head was only rebuilt about 3000ks ago with stem seals and a deck
will supply new head gasket with it to make the rebuild easyer
this setup was running mint with a big port ecu
has bottom end knock ..............500$ take it away from knox melbourne in vic
can supply with aus spec gearbox and extreme clutch with about 2000ks on it and a heavy duty flywheel for with it all up for $1000
call 0413449246 if your keen as im not on here much so pms are kinda useless cheers reg fink
wats going in the 86 now?
