would depend on the model but i have heard au's are 6kg ish
Hi
Trying to find out what spring rate the Falcon springs in the back of me keto are.
Pretty bloody stiff I know that much. Not sure exactly which Falcon they came from. Just ruff idea would be nice.
Thanks.
HAHAH I LOVE BOOST LOOSING!!
Also depends on how short they are. Usually around the 5kg/mm.
Just remember you can hide shit springs with good shocks but not the other way around, so make you you have a decent shock to match with them.. Anything is better then stock.
true ^. i had 230mmish? falcon's in the back of my old ke70 sedan with stock shocks (probably 20y.o) for awhile.
Man, that f**king sucked..
Ok thanks
Didn’t realize rate was proportionate to height.
5 or 6 sounds good. Thought it might have been more.
Running sierra shocks. Good so far.
yeah it effects kg rate by how many coils you cut off not sure how to calculate but i think someone tried to make some formula of calculation to roughly show you how, but was most likely lost on old forums
wats a decent mm to cut it to? 230mm?
Mine are cut to 225mm sits perfect, Also handles perfect with 8kg coilovers in the front. Awsome balance.
" I swear its stock officer. Just don't get me to park next to another Ke70 "
200mm or lowar
