Item: Toyota mr2 aw11 G limited japan import
this car must be seen!
perfect inside and out
Item Condition: great condition:
160,000kms on the car,4agze motor has done 20,000kms
mr2 s/c E51 gearbox brand new exedy 3 puk brass button clutch kit,
exedy lightend flywheel done 10,000kms
majoraty is highway driving i live 30kms away from work and travel to brisbane every weekend.
Reason for Selling: im doing alot of traveling so i need something a little bigger.
Price and Payment Conditions: $9000 ONO
open to swaps.
Exhaust: custom 2 1/2 inch the whole way through
Suspension: TRD struts super low K mac springs, full twos r us polyurathane kit
new tyre rod ends inner and outer
Wheels: 15" RSA lightweight wheels nexen low profile tyres 95% tread left on all tyres they are all near new
Modifications:
lightweight 15in rims
aftermarket springs
full jap spec 4agze from a levin gtz. engine conversion.
map censord not AFM.
solid snap ring lightened and forged pistons.
microtech LT10s.
pod filter.
has an aftermarket exhaust.
4agze engine mounts.
4agze starter motor.
topgun leads.
iridium spark plugs.
custom alternator bracket.
water pump.
timing belt.
new breakpads.
nock sensor.
o2 sensor.
new injector O rings.
custom switch that turns the supercharger on and off.
custom made wiring loom.
serviced every 5000kms with castrole edge oil.
custom paint job in acid green
clear indicators (front and sides)
Stereo Audio / Visual: JVC head unit witch is mp3 compatible and 2 Kenwood 5'' speakers.
cross over with 2 pioner 6'' and tweeters all custom mounted in the doors
interiour is perfect i have had alot of stuff replaced.
Estimated Power: dyno at 150hp atw's on 12psi
Extra Info:
spent over $8000 on the motor and gearbox alone, (have recepits for everything)
this car has alot more potential could reach close of 200hp ATW's with a bigger crank and water2air intercooler.
i also have a high flowed TD05 turbo with manifold, water to air intercooler. a little more to do to get the turbo conversion finished it will all come with the car for a little extra cash if interested.
call or msg anytime
Daniel
0421188075
(02)66540990
spanieldabeatboxer@hotmail.com
Pictures:
