Results 1 to 10 of 49
Thread: Lock Spacers - run 2?
    Veteran Beau's Avatar
    Beau
    Default Lock Spacers - run 2?
    Hey guys i was just curious if anyone runs two AJPS type lock spacers? Or is it possible?
    Does it give even more lock? Or is it just a waste of time and money and 1 is fine on its own?
    Thanks
    Senior Member Simon-KE70's Avatar
    Simon
    doesnt work that way, the rack can only travel so far before it runs out of teeth, the lock spacer allows the rack to travel slightly further to use all the available teeth.
    if you require even more lock then rack spacers and PS arms then theres only a couple of options left, and that is modified steering arms (IE, sell the PS arms and cut and shut some stock 86 arms shorter then PS arms) and playing with longer LCA's etc
    Beau
    Quote Originally Posted by Simon-KE70 View Post
    Thanks Simon. I had heard mixed rumours so i just wanted set it straight in my mind. i dont really need anymore. But then again i wouldnt say no to more.
    Thanks for the extra tips!
    Simon
    no mate, i hear it all the time, some people assume they are magical things that keep adding more lock the more you put on
    on nissans, if you run too many you run into binding issues which is a result of the tie rod hyper extending.... when this happens... you cant bring the steering back from full lock at all, not a nice feeling!
    Veteran biggo's Avatar
    Nick
    Noosa
    I cut more teeth into the rack. The plan is to run 2 lock spacers but i highy dont reccommend it as it renders the rack pretty useless. Plus its not very safe.
    One problem i have with mine is the calipers are hitting the castor arms. Still yet to figure out a way around it.
    Davey & Riki-lee
    South Australia
    Seaford SA
    long control arm? ^^
    Our introduction - Click here
    Nick
    Noosa
    i was thinking that but meh.
    might just try out some nrca's first
    Simon
    bit of a bandaid solution that one.
    longer LCA is the way to go
    Beau
    Thanks guys! if i need more i'll look into more options. But i think my current set up is great and if anything id rather have more response then lock.
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    you probably can try put a washer/spacer after AJPS lock spacer
  1. AJPS lock spacers
    By AJPS in forum AJPS
    Last Post: 28th March 2012, 07:36 PM
  2. lock spacers
    By hachi_dk in forum Technical - Questions
    Last Post: 10th August 2010, 07:33 PM
  3. lock spacers ???
    By 70rolla in forum General Topics (No Technical Questions)
    Last Post: 3rd August 2010, 07:56 PM
