Results 1 to 10 of 18
Thread: can EASILY swap a st 20v for a bt 20v
    Senior Member dave2221's Avatar
    Default can EASILY swap a st 20v for a bt 20v
    have a st 20v
    thinking of swapping it for a bt 20v
    is there any tricky stuff that needs doing?
    or should all the parts just line up? i.e water system, fuel and wiring harness?
    Gunner
    i believe there is differences in th harness, obviously with the air flow to map, but I am not sure about anything else.
    why not just freshen up yours?
    easier to swap motors than to pull mine out, change things get parts once you know what needs replacing, then installing parts, put motor back....
    swapping should be a weekend event
    i have EMS engine management.... does that change the way you install bt20v and st20v
  • #4
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I personally haven't worked with 20v's but from what I understand everything you have on your ST should bolt to the BT. I do believe LittleRedSpirit swapped out his BT for an ST pretty easily.
    Having already got an aftermarket ECU it should be a breeze too.
  • #5
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    i reckon freshen up the st dave your still going to be in the same boat if the blacktop hasnt had a rebuild since factory
  • #6
    yeah
    just thought it would be eaiser to do an engine swap (cause the hachi is a daily) than trying to change piston rings and shit.
    ill sell my st20v as is, and yeah someone else can do it before it goes in their car....
    it still runs ok, just needs piston rings and valve stem seals.
  • #7
    we will see whats what after the rx7 upgrade
    still hunting a r32 brake master....... dont want to pay 500 for a new one from factory if i can avoid it
  • #8
    prolly not worth the effort..
    best option would be to freshen up the ae101 and maybe throw some cams in it..
    paint the covers black if its so important that u have a blacktop lol
  • #9
    Lawrence
    Wollongong
    So are you getting the BT rebuilt before you put it in?
  • #10
    wasnt going to.
    which does potentially pose a problem.
    i should just fix up what i have got.....
    new HG, rings, seals and a retune.
  • Page 1 of 2 1 2 LastLast
    1. WTB: 20v bt/st engine and t50 gearbox
      By ballos in forum Cars or Parts Wanted
      Last Post: 16th May 2011, 11:41 PM
    2. ST or BT 20v for 7AGTE Build? Keep vvt?
      By PRIMRK in forum Technical - Questions
      Last Post: 13th September 2010, 07:03 PM
    3. Is there a difference between bt and st 20v head???
      By slider4life in forum Technical - Questions
      Last Post: 12th July 2010, 07:50 AM
    4. are bt 20v and silver top 20v cam covers the same??
      Last Post: 1st April 2010, 06:08 PM
