installed a AEM wideband Air Fuel ratio gauge yesterday... now the road tuning can begin.
its running super rich right now.
Yes, chop them up!
No, keep them clean!
its for sale, .
hopefully someone will buy it and restore it rather than cut the panels out of it.
i got the car tuned, with a safe tune i made 95.8Kw at 6450rpm and 150.2Nm at 5900rpm.
the tune is still a little rich but once i fine tune it myself it should push over the 100kw mark.
i also need to set up cold starting and fine tune the cruise map then ill have some economy.
but the car is much better to drive now and i can finally start to enjoy it again, but i must say driving it around with under 40kw was quite a mission, but i feel like i know the car a bit better, without the power i had to drive it completely different to be able to keep the flow of traffic and to keep up with my mates and the way they hoon.
throttle control is key.
a bit more of an update for this car, some pic's of after it was rego'ed and some new bits for it.
i had my bro make me up a vac tank, after installing this my A/F ratio was much more stable. it also made it so i could trim my tune a little for more power and fuel economy.
then the tacho i ordered finally came.
now its fitted.
heres one that a few of you guys might have seen floating around facebook.
hey mate car looks awesome.n sounds like a pretty good lil 20v you got in it.
im just curious as to someone else with a microtech on a 20v.
how do yo find your half thrttle to full throttle vac signal? im doing my tune on road atm and the difference betweenhalf throttle vacuum and full is about 2hg and both fall within the 5hg map cell?
or are you tuned in tps mode??
Im tuned on map, I did have a big difference but then I installed the vac tank I mentioned above, it made a massive difference. I would recomentd you get one.
