Results 1 to 4 of 4
Thread: pilot bearing instal
    Member richo's Avatar
    Matthew
    Capalaba
    Default pilot bearing instal
    hey
    im just wondering how you instal the pilot bearing between engine and gearbox. its way to tight to just push or tap in and ive tried freezing it but it still wont go in. any one else had this problem?
    todd
    use the old one and line it up on the new one and use it as a dolly sort of thing. or use a block of wood.it will need persuasion with a hammer.just never hammer directly onto the new bearing obviously otherwise u will kill it.
    it takes time but it will fit. unless u have the wrong bearing.
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    I installed mine last week into 20V Flywheel, used a socket that fitted the outside of the bearing and a hammer, went in quite easliy.
    Bearing should measure 28mm OD, 12mm ID and 8mm Deep with part no. similar to NSK 6001V
  • #4
    Matthew
    Capalaba
    how far in should the bearing go????
  • Similar Threads
    1. URGENTLY NEEDED - Thrust Bearing Carrier ae71 + bearing
      By ethsar46 in forum Cars or Parts Wanted
      Last Post: 18th March 2009, 04:03 PM
    2. Spigot bearing
      By QUINN in forum Technical - Questions
      Last Post: 3rd December 2007, 12:00 AM
    3. Spigot Bearing
      By Monk in forum Technical - Questions
      Last Post: 23rd December 2006, 01:33 PM
    4. Bearing Part No.
      By steroidchickens in forum Technical - Questions
      Last Post: 7th December 2006, 11:10 PM
