Results 1 to 10 of 12
Thread: Throttle cables
    matt
    sa
    north
    Default Throttle cables
    I thought about tacking this on to the carby thread further down the page but i didnt want to get too far off topic.
    I recently replaced my solex carbs with a brand new set of solex carbs and have found that the stock sprinter throttle cable no longer reaches my linkage. Its only off by about 50mm and I remember someone once saying that there was a throttle cable off another toyota which bolted straight in place of the 86 throttle cable but was longer.
    So any suggestions...Im trying to keep it neat otherwise I would have put some ghetto backyard solution together by now
    Davey & Riki-lee
    South Australia
    Seaford SA
    my KE70 cable is faily long and might work (or be too long).
    maybe try that?
    Our introduction - Click here
    Mt Macedon
    Most Toyota cables I've looked at will fit. Just go for a walk around a wrecker and see what you can find.
    Or alternatively, I've heard rumours that a JDM AE86 throttle cable is only $60 genuine from Toyota. Just rumours though.
  • #4
    matt
    sa
    north
    I had a feeling it might have been a keto that had the right size throttle cable. 4k due to the carby being on the other side of the motor? I cant remember, its been a while since Ive looked in a ke70 engine bay
    Hen, is the jdm cable longer than the adm cable?
  • #5
    Davey & Riki-lee
    South Australia
    Seaford SA
    yeah the ke induction side is on the other side of the motor so the cable is fair long. i have used this cable with my 4agze tho il get a pic up tonight when i go home to show you how much there is hanging around
  • #6
    matt
    sa
    north
    Thanks ae70...
  • #7
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    EP92 Starlet all the way (what I've got on my AE71).
    They are longer by about 70mm at a guess.
  • #8
    Davey & Riki-lee
    South Australia
    Seaford SA
    heres my jungle:
  • #9
    Ferny Grove
    route the cable under the booster and it won't be such a stand out
  • #10
    Davey & Riki-lee
    South Australia
    Seaford SA
    Yeah i just did that after the photo, just a guide to see how long the KE70 cable is.
  • Page 1 of 2 1 2 LastLast
    1. handbrake cables for F-series
      By 1jz jakey in forum Technical - Questions
      Last Post: 31st July 2011, 08:38 PM
    2. handbrake cables
      By Fozz in forum Technical - Questions
      Last Post: 19th November 2009, 10:22 PM
    3. Throttle cables
      By kaneO in forum Technical - Questions
      Last Post: 22nd November 2007, 12:41 PM
    4. what have you done with your throttle cables????
      By HiLtOn in forum General Topics (No Technical Questions)
      Last Post: 27th August 2007, 01:24 AM
