Results 1 to 9 of 9
Thread: kyb agx shocks
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default kyb agx shocks
    do you need spacers on the bottom to use them ?
    Senior Member Dylan's Avatar
    Dylan
    yes or cut the strut down to suit
    Elite rthy's Avatar
    Leo
    Tulla
    depends which model
    Ferny Grove
    really a very vague question
    mr2 or ST185/205
    if going coilover i wouldn't run a spacer under either, i'd get the strut shortened.
    if running conventional springs, actually i still wouldn't space them up, you can space them down using a certain piece out of a wet leg strut (stock 86 strut thats never had inserts) that will act as a (roughly) 40mm spacer which helps
    quoting what shock you want to use will make the answer a lot easier/specific
    Dave
    Western Suburbs
    st185's, struts are short as i think now ? atm running trd yellow short strokes
    Senior Member 45aken's Avatar
    Marko
    if you use the st185 im pretty sure they are 70mm shorter,
    i shortened the strut 50mm then used a 20mm spacer before i went s13.
    Veteran slydar's Avatar
    Dimitri
    dont run a spacer, not needed. theyre the same body length as youre trds (ae92 based) insert. but the longer stroke means you can get away with using them without a spacer.
    i never use a spacer in any of the coilovers i build for people, and no ones every complained their cars too low.
    Dave
    Western Suburbs
    thanks slydar ur a champ (:
    Moderator Frak's Avatar
    Jamie
    AE86 will be interesting to hear your opinion after putting the AGX's in and making a comparison to the TRD yellows. I have used TRD yellows before and quite liked them but have never had AGX's.
    I recently fitted KYB Climbgears to my AE111 and they have lots of compression and rebound dampening, quite suprised actually.
  1. ae86 struts + kyb agx st185 shocks
    By ae86 in forum Technical - Questions
    Last Post: 15th January 2011, 04:10 PM
  2. KYB AGX short stroke shocks
    By shawn_26 in forum General Topics (No Technical Questions)
    Last Post: 14th March 2010, 11:10 PM
  3. **kyb agx st185 short stroke adjustable shocks**
    By ae86 in forum Car Parts For Sale
    Last Post: 14th November 2009, 12:59 AM
  4. has anyone brought any kyb agx at185 shocks in adelaide?
    By 70wagon in forum Adelaide & SA Events and Discussion
    Last Post: 24th February 2009, 11:15 PM
  5. agx kyb short shocks part number?
    By Fooly Cooly in forum Technical - Questions
    Last Post: 28th January 2009, 10:23 AM
