Results 1 to 2 of 2
Thread: Read before posting in tech questions!!!!!
    Veteran driftke70's Avatar
    Ryan
    Buderim
    Default Read before posting in tech questions!!!!!
    The tech questions of late have been abysmal, to rectify this others and I
    will be keeping a close eye on what is being posted. Will not even remotely
    hesitate to delete something that is basically nothing more than a poorly
    worded, structured etc topic.
    Firstly, things such as general maintenance and other minor things can be found VERY readily on Google. If it shows you have not taken the time to find the information your thread will be removed.
    Secondly, this site has already a very substantial amount of answers within these pages, all of which can be very easily found with a search.
    Thirdly, if the following template is not used your post will be removed.
    Name of topic - Model of part and problem.
    for example;
    - 20v silvertop, faulty spark
    - t series diff, whining
    - ke70 chassis, bent chassis, fixable?
    Within the thread
    CAR -
    MOTOR -
    USE -
    PROBLEM/QUESTION -
    OCCURS/STARTED WHEN -
    for example
    CAR - ke70
    MOTOR - 3sgte
    USE - drift/hill climbs/time attack/street
    PROBLEM - not running properly
    OCCURS/STARTED WHEN - I pulled the car to pieces
    or
    CAR - ae86 (jdm coupe)
    MOTOR - 4age 16v
    USE - drift
    PROBLEM - clunking noise from diff (t series/trd 2 way)
    OCCURS/STARTED WHEN - after last drift day, occurs when i turn sharply
    at lowish speeds.
    If it doesn't look like this, then don't expect your thread to be there, never mind an answer.
    Beally
    EDIT: also from here on there will a universal thread listing, all threads for certain topics have a set thread for them, to see the listing see here:
    wheelfriends.wordpress.com
    Mt Macedon
    Also, if you know something is on ae86dc, but can't find it with the search here, you can use Google. Just add:
    site:ae86drivingclub.com.au
    to your search. For example:
    T50 gearbox variations site:ae86drivingclub.com.au
    This searches both the forums and the FAQ.
  • Similar Threads
    1. posting
      By corknose in forum General Topics (No Technical Questions)
      Last Post: 11th May 2009, 10:11 AM
    2. Posting Wheels
      By bigm in forum General Topics (No Technical Questions)
      Last Post: 14th July 2008, 05:03 PM
