Page 1 of 13 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 125
Thread: Dk's jdm yo! skidder
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    Default Dk's "jdm yo!" skidder
    Hi guys.
    thought i'd post some info bought my vehicle
    General:
    ae86,
    levin,
    hatchback,
    1984,
    engineered
    Engine & drivetrain:
    Silver top 4AGE 20 valve running black top ecu
    Rebuilt 60,000ks ago (comp tested about 500k's ago and is 185psi across all 4)
    Dizzy relocation kit on front of heads
    twin thermo fans
    TRD 4-1 extractors
    Hi comp pistons
    Match ported head
    280mm disc brake rear end
    TRD 2way with 4.8 diff gears
    Heavy duty clutch
    air conditioning
    Supra fuel pump
    earls oil cooler and filter relocation kit
    T3 short shifter kit
    Suspension & brakes:
    t3 pw/s arms
    t3 adjustable LCA's
    t3 adjustable tie rod ends
    cusco camberplates
    RX7 4 pot calipers with bendix ultimate pads on 294mm mini coopers disks
    power steering
    AJPS adjustable panhard rod
    cusco strut brace
    AJPS 40mm RCA's
    AJPS drift button
    Interior & exterior:
    zenki front lip on kouki front bar
    OEM factory side skirts
    MR2 front seats
    factory electric sunroof
    Power mirrors
    Tinted Windows
    Alpine head unit MP3 Player
    Alpine 6" front splits
    VDO 6" rear splits.
    resprayed
    5 point CAMS approved half cage
    2x 4 point TRD harness'
    whiteline tailights
    bonnet pins
    uncracked dash defended by AJPS dash matt
    vertex rear bar
    DMAX +25mm oversize front guards
    PICS:
    how she is now
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    quite nice man...
    BENT MECHANIX - Garage 20:
    Jamie
    very nice, clean and has a sunroof awsome
    Veteran drift kid's Avatar
    Glossodia
    can i ask, why did you go 5 stud? rest of the car's pretty schmick, good work
    Josh
    Mid North Coast
    wow, that 20v conversion looks stock, does it have working air con, even got cold start too, nice man,
    nice... have you found any dash mat yet? AJPS has some if u havnt get one
    Filip
    Jozzaville
    got the car with the 5 stud pattern and probly was changed from 4 to 5 stud for a larger selection of rims?
    yer mate everything working.
    air con, cold start, everything
    havnt found any.
    ordering one from AJPS in the next couple days.
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    id say 5 stud would limit your selection of wheels
    unless 18x9-0 VSK-F's are your cup of tetley
    Filip
    Jozzaville
    Well my 5 stud pattern fits holden stockies so slap them on the back and use my current data champs as quality fronts.
    And in future when I either 2jz or 13b this bad boy, some big ass wheels will be needed. But that's at least 2 years away
    Felix
    Inglewood
    that means 5x120, so commy and beemer wheels will fit, but unfortunately you wont find anything under 16", also "Datachamps" are are generic multi-label chinese made wheel, they by no means are "quality fronts"
    sorry but just being honest
    Oh PLEASE dont 2jz or 13b this car!
  4. 14/6 set and 15/6.5 pair brisbane
    By Kowna in forum Car Parts For Sale
    Last Post: 14th April 2009, 11:14 PM
  5. WTD: 15 SSR MESHIES 7.5 or 8 or 8.8 around ZERO offset!
    By ludachris in forum Cars or Parts Wanted
    Last Post: 28th January 2009, 10:48 PM
