Results 1 to 9 of 9
Thread: 4AGZE blowing smoke
    Member jamekins's Avatar
    ACT
    South Canberra
    Default 4AGZE blowing smoke
    Recently I have noticed that my GZE has been blowing smoke when it comes on to full boost. And to be frank I have no idea why. It has also slowly been losing oil and I can help but think the two things are related. Has anyone had this happen or can hazard a guess as to what's going on? Any help would be awesome
    alex
    piston rings
    Member Aezion's Avatar
    Seb
    yer sounds like your piston rings are stuffed
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    my gze used to blow smoke when reving it up quickly after cruising. it was just running rich.
    is it constantly bowing smoke when reving it higher or just to start with?
    Member boky's Avatar
    nathan
    vic
    kilsyth
    what colour smoke
    Senior Member kaibeecee's Avatar
    Pete
    sounds like the valve stem seals could use replacing.
    alex
    Quote Originally Posted by riojin View Post
    running rich wont use oil though...
    Senior Member KE70's Avatar
    Alek
    Lalor
    The colour of the smoke with give you a better indication on what is stuffed. Also the smell sometimes.
    Mt Macedon
    I agree with most of the above, but I wouldn't jump to rings yet. Colour of the smoke is important. Grey = oil burning, black = running rich. Standard ZE management is rich. Your oil usage may be totally unrelated.... then again it may not, but let's hope it is.
  1. my new 4agte blowing lots of white smoke
    By Nic19 in forum Technical - Questions
    Last Post: 14th December 2009, 06:46 AM
  2. 4agte turbo blowing smoke..
    Last Post: 9th February 2009, 10:12 PM
  3. 86 blowing smoke?
    By simonster in forum Technical - Questions
    Last Post: 7th May 2008, 12:31 AM
  4. 4age blowing black smoke
    By deanoo in forum Technical - Questions
    Last Post: 19th January 2007, 07:01 PM
