Results 1 to 3 of 3
Thread: Oil pressure sensor
    Elite rthy's Avatar
    Leo
    Tulla
    Default Oil pressure sensor
    Is there another place to put an aftermarket oil pressure sensor on the 4age (7rib bigport) block?
    i had a look around online and people have used Tee pieces inorder to keep both factory and aftermarket sensors.
    my question is if there isnt any other place to put the sender, will this sort of setup still give an accurate reading?
    also quick oilpressure facts from twincam.info
    Regarding the oil pressure Ellery's Corolla Manual says;
    At idle speed:
    More than .3 kg/cm-squared (4.3 psi, 29 kPa)
    More than .6 kg/cm-squared (8.5 psi, 59 kPa)
    At 3000 rpm:
    2.5 - 5 kg/cm-squared (36 - 71 psi, 245 - 490 kPa)
    At 6000 rpm:
    More than 3 kg/cm-squared (43 psi, 294 kPa) 4A-GE only
    Senior Member Dylan's Avatar
    Dylan
    what about something like this?
    The setup you mention should still give an accurate reading
    Elite rthy's Avatar
    Leo
    Tulla
    yea im already running an oil cooler so not sure the oil filter will fit with another adaptor.
    might give the T piece a shot
  1. Oil Pressure Sensor Calibration Table
    By Andy San in forum Technical - Questions
    Last Post: 23rd November 2010, 07:09 PM
  2. 4age Oil pressure sensor thread size?
    By eightsixboy in forum Technical - Questions
    Last Post: 9th September 2008, 08:30 AM
  3. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
  4. WTB: 4age Oil Pressure Sensor
    By d-shiznit in forum Cars or Parts Wanted
    Last Post: 15th August 2007, 07:28 PM
