Results 1 to 8 of 8
Thread: 4AGE odd idle issue
    Senior Member JinxD's Avatar
    Ash
    Default 4AGE odd idle issue
    Hey guys just installed a new Bigport, having some idle issues.
    Upon start up it hunts idles from 3400,to 5000rpm without touching the throttle
    Stock computer, wiring etc only real mod i can think of is 3.6kg fly wheel
    any thoughts ideas ?
    Cheers Ash
    GhettoGarage.org
    Quote Originally Posted by mild seven View Post
    i cant stand "JDM faggots" (people outside of japan who are MORE JDM than people in japan)
    Veteran Skylar's Avatar
    Ken
    Set TPS. and maybe butterfly is open for it to be revving up that high.
    Ash
    forgot to mention it has no TVIS throttle body butterfly isn't open
    ill check tps
    GhettoGarage.org
    Veteran Nikkojoe's Avatar
    Tom
    If it idles all the time in that range, you have an air leak in your intake somewhere. Make sure you got new gaskets around your intake and its all done up tight.
    So when you say this:
    You mean the tvis plate is gutted? If so, did you weld up the hole for where the shaft passes through. If not, this will be your high idle/air leak.
    Ash
    yea its got a blank plant in liue of
    GhettoGarage.org
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    Sounds like the cold idle valve on the bottom of the throttle body. Is the idle screw screwed right in and still idling that high ?. I have the same issue at the moment and have had to revove that assy from the bottom of the throttle body abd then inbetween it and the throttle body have put some aluminium tape right across it to blank that assy off. It will run fine other than on initial cold start won't idle untill, so just hold the accel for 10 -20 secs , than it should idle if you have the idle screw ount about 1 turn. Then once up to temp adjust your idle to suit.
    Note this is only a tempeary fix as that part is approx $300 trade from toyota.
    Another way to confirm this is if you have no other air leaks put you hand totally oer the inlet to block it off with eng running and if the engine doesn't stall it sounds like what i have just described as it is sucking air throgh this valve on idle.
    Try that and see what happens.
    Good luck
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Tom
    For it to rev to 3400-5000 would mean that he has a massive air leak. Cold start not working would only rev up to 2500-3000 if that (thats assuming that the idle screw is wound all the way down). It could be a combination of the two but more than likely an air leak.
    Could even be a cracked intake manifold.
    Khai
    sorry to steal your thread JinxD, but im having some idle issues with my 4age smallport aswell. It idles normally pretty much all the time but on initial cold start it will stall if i dont keep my foot on the gas for a good 30 seconds...
    anyone have any ideas?
  1. 4K-C idle and running issue.
    By AE86 Spoontah in forum Technical - Questions
    Last Post: 14th June 2010, 09:05 PM
  2. 4age, ae82, ae92, ke70 odd bits [ADL]
    By shuvke70 in forum Car Parts For Sale
    Last Post: 1st May 2010, 11:11 AM
  3. 4age idle problem
    By carolla in forum Technical - Questions
    Last Post: 18th November 2009, 08:59 AM
  4. 20V idle and rev issue
    By fat20v in forum Technical - Questions
    Last Post: 4th August 2009, 12:06 AM
  5. What does a 4age idle at
    By deanoo in forum Technical - Questions
    Last Post: 6th December 2006, 08:03 AM
