Results 1 to 7 of 7
Thread: need advise on what oil to use...
    Senior Member koulouris#03's Avatar
    Nsw
    EarlwoodNsw
    Au
    Default need advise on what oil to use...
    hi guys.
    i need to get some advise on a service.
    i have a turbo 4age motor and need to change the oil and oil filter in it.
    what oil and oil filter should i look at getting for this application???? any suggestions???
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    I'd go with the stock toyota oil filter and a fully synthetic oil, if you can afford it. As for the oil weight, the reccomended 4agze oil should do fine.
    c
    Quote Originally Posted by koulouris#03 View Post
    hi guys.
    I would actually use a thinner fully synthetic oil around 10w-35 or you have the chance of blowing your turbo seals.
    As vezza said use the stock filter
    Gone
    Joel
    Picton
    http://www.ae86drivingclub.com.au/fo...read.php?t=971
    u dont need to go that thin and u wont blow turbo seals
    c
    Quote Originally Posted by sundee86 View Post
    If you run a 20w-50 you can
    Gone
    Joel
    Picton
    Quote Originally Posted by egg_83 View Post
    no one said anything about running 20w50 here... 10w40 or 15w40 is fine
    serious compitition cars run 5w50 or 10w60
    i dont see how u should blow turbo seals with oil.. unless u use Penrite 80 or wateva the heck it is.. but thats pretty much honey
    Reeece
    Casula
    if you want to keep your turbo i wouldnt run any higher then 15w 50-60.. turbo's life is critical with it comes to oil supply and water feed
  1. FS: Omori Oil Pressure & Oil Temp Gauges
    By Nebuchernezzer in forum Car Parts For Sale
    Last Post: 14th November 2007, 07:50 PM
  2. Another Project rusty? advise needed!
    By Ade_Mc in forum Technical - Questions
    Last Post: 20th July 2007, 07:58 PM
  3. omori oil filter relocation kit with oil temp and pres guages
    By ae86 slide in forum Car Parts For Sale
    Last Post: 21st March 2007, 07:04 PM
  4. need your advise people
    By quoccy in forum General Topics (No Technical Questions)
    Last Post: 26th February 2007, 09:10 PM
