From factory, injectors 3&4 (the ones that are leaking) share a trigger from the ECU. If this wire got shorted to ground (either somewhere in the loom of if the ECU shat itself somehow) then the injectors would stay open and drop lots of fuel into the inlet.
May be a long shot, but is easy to check with a multimeter.
