Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Rear guard welding???
    Senior Member Ksevn-T's Avatar
    Default Rear guard welding???
    hello,
    Looking at chopping out my rear guards on my ke70 (not to mention the rust) and weld on ke70 front's. How far do you have to cut the guard back to? Do you have to weld that seem halfway? Arent you left with a sharp edge inside that guard, once the new one has been welded on? Has anyone got any pics or tips and tricks?
    Alex
    数独のガレージ "Sudoku Garage" <3<3<3
    "Where on earth is Carmeon Slydar-aigo, where on earth could he be!"
    Slydar will answer all your questions.
    Jason
    Nundah
    You cut the guards where the flare meets the body on both the fornt and rear guards... then you'll have to trim the Front guard part down to suit the contours of the rear of the car and then weld it on...
    Should be no sharp edges persay inside the guards just a weld. Which you could grind/flap disk smother if you were concered anyway....
    This is just my ASSUMTION...
    The one and only Slydar will no dobt answer all your questions.
    As he;s done this quite a few time now for ppl.
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    Same deal as a bolt on flare, cut off, put on.
    To answer your question:
    Cut the front guard along the flare, same with rear. Draw reference lines on the flare and quarter once you have it positioned where you would like so you get it in the right spot. Trim whatever needs trimming to suit.
    What seam are you talking about? The one in the middle of the rear flare?
    No, you don't have to. I haven't and the car is fine. Up to you though.
    For the sharp edge, to as said above, get under it and grind it back. No brainer.
    Man, just get in there and do it, no one will be able to give you a detailed explanation like you actually getting in there and having a go. It's what I did, turned out good!
    Smoothing the inside with sikaflex works good plus seals your welds etc etc.
    Veteran ae86's Avatar
    Western Suburbs
    awaits the king of modified guards to comment.
    Nic
    Mt Evelyn
    we did mine last weekend. grinded slits up the old rear guard and tapped them out tacked the old inner and outer together, then used the front guards lip to tuck over the old inner and out that was previously tacked. just need to bog n smooth them and then silicone the gaps underneath to make it water tight.
    i used more of the guards then just the flare, i ran it up the quater a lil so its more sturdy then just the flare itself
    cheers
    nic
    Veteran stahlz_ae86's Avatar
    Paul
    if you get a chance nic throw up a pic of the final product. I'd be keen to see as your guards were quite the interesting
    Maybe you can read over your post and rephrase it ? I can't follow what you did. And I do have higher than a 3rd grade reading level.
    Senior Member resol's Avatar
    steve
    vic
    well how big do you want your gaurds? i can flare them a long way! but if you want wide STOCK looking guards then weld on is the way.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  1. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  2. 86 - Rear guard flarage
    By Gunner in forum Technical - Questions
    Last Post: 1st August 2009, 11:30 AM
  3. Left over. rear shocks / bonnet / drivers guard LEVIN etc
    By Evan in forum Car Parts For Sale
    Last Post: 2nd June 2009, 08:53 AM
  4. guide to rear guard flaring
    By slippry in forum General Topics (No Technical Questions)
    Last Post: 5th January 2008, 05:48 PM
  5. welding inner guard to outer
    By ae86 slide in forum Technical - Questions
    Last Post: 9th June 2006, 08:05 AM
