also the tailshaft issue. ie what can i use if there is anything?
cheers
jarrad
i have got my self a nice little 18rg which i plan on putting in my ke70. the motor came out of a ke36 pannelvan i think it is, so its got custom engine mounts and it sat perfect in the pannelvan so that the drop at the back of the sump sat right at the front of the crossmember so that the shifter sat in its normal hole but they have a different cross memeber so i need to no what to use. so if you no any thing about this please give me a yell and let me no!
also
my questions are
1) is there any one here who has put one in there ke70 that could help me?
2) dose any one no what crossmember i can use? if there is one?
3 dose it all have to be custom stuff?
any help on this will be appreciated
thank you
jarrad
cheers
jarrad
can any one help me out with this??
k i'm going out on a limb here but because he has altered the enigne mounts to fit into the ke36 crossmember that originally housed a 4k this should bolt in to your 4k crossmember??? this is just a slightly wild guess but i thought i'd throw it out there..
yer i thought of that but they have a different cross member to the ke70.
dus ne one no if i could bolt the ke36 cross member in to my ke70?
or could i use a 3t t18 cross member coz i have one of them also.
You don't want to use the T18 Crossmember, as it has no provision for Rack and pinion steering, as fitted to your KE70. Unless you want to modify it of course.
The 18R-G is a front-mid sump motor. I can't recall where the sump lies on a 4K.
Chances are you're going to have to fabricate some engine mounts to suit your application. Unless an Ae71 crossmember is a closer fit, but i doubt it.
Have a look where your sump lies and go from there.
hey man i done a 2tgeu into mine im pretty sure there nearly the same engine and mine bolted strait in with the stock 4k cross member so u should have no problem
that engine sat way too far foward in that van, bring it into work weel mount that junk for you.
AE86 THE BEST
lol that would be good but i dont have a spare million lying around tho
but yer i dont like how far forward it sits in the panno
its a front sump motor but im hopping it would be the same process of the 2t-ke70 process coz theres lots of information on that
