just get the regular type
i can send you some
pm me
Hi all,
I need to purchase some inner tie rods one of mine is rooted.....but which ones???
I have an ADM AE86, and I'm running corona LCA's and jdm power steering arms.
I've read somewhere that if you run power steering arms, you should run power steering inner tie rods.
I don't know how true this statement is, nor do I know the difference between power/ non power tie rods.
So what type should I get?
i can send you some
pm me
Cheers Dave
Pm'd
Definitely BS, standard rack ends will be fine.
FWIW i run standard rack ends, and standard tie rod ends with corona LCAs and Custom Shortened arms (Shorter than ps)
cheers for the info.
AE86....robbing me! check the build.
http://www.ae86drivingclub.com.au/fo...read.php?t=445
